Environment Rendering issues
HI guys,
I was trying to render a city scene using 'Streets of Steampunk' Just doing a normal 3delight rendering, supposed to work fine.
I should get something like the first image I attached (The street scene, not using characters now) and I get the second file instead. What is going on? I haven't used DAZ much lately but OMG, no wonder. Every time I open it tere are major issues that shouldn't be there. WIsh they made it usable instead of ust adding new content that never works properly..... End of rant
ANyways, any help would be appreciated. This is just weird.
That set lists only Iray materials. You might be able to get a useful conversion out of https://www.daz3d.com/rssy-iray-to-3delight-converter-and-merchant-resource (or I think there is a free script posted to the forum, though I don't have a link to hand) but if not you would have to use the suplied textures to build your own 3Delight materials.
Well, I appreciate the help but this is confusing. The product shows 3Delight and Iray settings once installed, and in studio I loaded the scene supposedly made for 3Delight so in theory that shouldn't be an issue.
It does have a 3Delight version and it renders OK for me in 3Delight. Did you set your render engine to 3Delight?
Edit: I rendered in DS 4.21.1.29 Public Build (Beta).
I know nothing about 3Delight as I have never used it before. However, I do have this product and so I tried to see what would happen. I loaded the 3Delight version, zoomed the viwport out a bit, swapped the render engine over to 3Delight and hit render. Got a nice black square because I didn't realise it had no lights by default, but when I added a distant light and hit render again I got a normal-looking scene - see attached.
So, the product does work in 3Delight although I have no idea why your render looks like that unless you really changed the settings from the defaults?
Sorry, the product page lists only Iray so I didn't check further https://www.daz3d.com/the-streets-of-steampunk
In that case it's probably using a Shader Mixer shader (like the Age of Armour SSS Shader) and sometimes that will fail to compile the required RSL code for 3Delight - you can try clearing the brickyard folder for %appData%/daz 3d/Studio4/Temp/ and then restart the render if that is the case.
As far as I know I didn't change any defaults.... THis is rather bizarre
Could it be that you simply overexposed the scene with too strong an environment light or other light source? Because the sky background, that supposedly is not reacting to diffuse rays, seems to look ok.
If you would show us your rendering settings, it would be easier to see what's going on.
