GENERAL FREEBIE REQUESTS Part 2
Adding to Cart…
I happened across these, and they seem to be about what you're looking for. They're for M3 but should still work for genesis with some adjustment. http://www.poserclub.net/index.php/freebee/item/48-f48
Looks like Poser Club is down for maintenance.
Luckily, this set is in the Wayback Machine:
http://web.archive.org/web/20150108020428/http://www.poserclub.net/index.php/freebee/item/48-f48
I am actually looking for Phoenician-looking stuff in general; I would like to make a scene aboard a Phoenician merchant ship. Clothes, beards, even some Mediterranean skins would help a lot. I mostly use the Gen4 figures, but I have most of the free figures that will work in Poser, plus all the people that came with it, and I'm willing to refit stuff, but I only use Poser so Genesis won't work. Thanks.
Those hats actually look like Mylochka's Vulcan Hats, or they could be substituted in a pinch for some of them.
http://www.sharecg.com/pf/full_uploads.php?pf_user_name=mylochka&division_id=0&s=dd&pn=12
I went over to RDNA and search for the adventurer head gear set but can't find it, unless I am overlooking it. I have searched both the downloads section where many past freebies are available, and also the free 3D model section. Is it possible to share the direct link?
NO NEED TO WORRY! When doing a web search on Google it directed me to redeyecat site who share the direct link on her website! :)
I happened across these, and they seem to be about what you're looking for. They're for M3 but should still work for genesis with some adjustment. http://www.poserclub.net/index.php/freebee/item/48-f48Thanks. I'll have to test them out.
I would check out Rosemaryr gallery at sharecg: http://www.sharecg.com/pf/full_uploads.php?pf_user_name=rosemaryr for clothing for the Gen 4 figures. They are Poser Dynamics which you should be able to work with.
Perfect! Thank you!
That skin tone is very hard to find, I'll probably have to make it. Would be nice if I could start with something fairly close, though. I would even pay a little for it, if I could find a North African/ Mediterranean looking skin.
...For Michael 4 or Apollo or one of the Poser guys.
I didn't have the direct link...I had the hats in my backup files...so I needed to hunt it down, too. :red:
Thespisis used the Apollo body1 and face1 maps for her Sexy Demon (who is based on a Middle Eastern actor) Apollo character with a base color of 255,240,245, instead of white.
Don't have Apollo installed right now, so I can't show a render, but if I recall, that does a passable Middle Eastern/Mediterranean skin.
Have a tricky one. A 7-shot revolver. Specifically a Nagant M1895. I found one so far, but it's $40 for a low-poly model with no textures.
Thanks, I'll search for it.
I tried it, it looks very good. I never would've thought changing the diffuse color to pink would be the way to go, but somehow it works. :)
I'm having some trouble with Apollo's eyes (one of them is white, no matter how many textures I try to inject) but this isn't the right forum for that.
Check cornea opacity, or reflectivity.
I've used that character a couple of times in the past and figured since he was of Mediterranean origin, his settings would probably work for you. There are a couple things that Apollo is perfect for that don't seem to have been duplicated on more recent figures...so I keep him around (along with some of the other old timers...like Sixus1's Behemoth 2).
Are there any albums (LPs) and seven singles (45s) around?
Funny how language doesn't always keep up with the tech. We still call collections of songs 'albums', and on the news, they talk about 'what the tapes show' for the South Carolina shooting, even there is no tape involved. Strictly speaking, 'album' should refer to collections of songs on 78 RPM records, which were collected into sleeved albums you paged through, similar to photo albums. Each record held one song on a side. A 78 RPM album prop, record player, and of course the records themselves, would make a pretty neat 1940s-'50s-type package -- possibly even marketable, although that era doesn't seem particularly popular for products.
Modeling a very flat cylinder with a hole cut out is pretty easy, I expect; texturing a disk surface, whether 78 RPM shellac, or 33 1/3 RPM vinyl, is probably a difficult thing to do really well.
Or wait until tonight...I'll have one up (OBJ only)...record, sleeve and cover. UV mapped, placeholder textures...supply your own artwork/labels.
I am unable to find a link so I'm not sure if it's still available, but if you can locate the Gramaphone by Sams3D, it is possible to set the opacity of all surfaces except for the record on it to 0, thus leaving you with just the record. It's not very high resolution, not sure how detailed your record needs to be. I haven't tried them, but a search for gramaphone in the Renderosity freebies turns up two others, maybe one of those or from another site too would work.
You could also probably apply your own grooves to the surface of a record (whether this one, a different one, a cylinder primitive, or whatever) by making a bump or displacement map that's just a bunch of concentric circles of varying sizes to simulate the differing appearance of different sections of the track across the record surface, although that would be a bit of work).
Do you have any CD or DVD models? I bet those could be easily resized and retextured to look like a record.
Thanks. I did look earlier this week, but unfortunately not quite what I was looking for.
Here's a render of it, so far...
I picked the album art because I thought it was rather appropriate... :lol:
Looks cool MJ
Very nice MJ!
Will the record label have it's own mat? I best get some textures :D
Here it is...just bare obj, sized in Daz native scale to import into Studio around the proper size.
Album art is strictly BYOB...I'm not touching that one, period. It's like a minefield, in a 'gator filled swamped surround by a piranha filled river on an island surrounded by man-eating sharks. Nope...not going there.
http://www.sharecg.com/v/80388/view/5/3D-Model/Vinyl-record
PS: It looks pretty cool mounted on a wooden plaque with a gold shader applied to it...too.
Yes, the record has 3 mat zones...Side A label, Side B and vinyl.
The sleeve and cover are the same UV layout, but they are separate items, so separate textures.
At some point I may make a texture for the album that is unencumbered...but not going to attempt anything for the cover art...unless maybe it's some Grateful Dead albums...
Grateful Dead .... are they still around? LOL
Thank you very much!
You're welcome, but you do know that now I just had to do it...(the turntable is from Turbosquid...a freebie).
A couple of oddities I noticed now that I made a full texture for it. The back side of the cover and sleeve are 'mirrored'...in other words, the texture is reversed. The A side label is on the right, B side on the left. I'll update the UVs at some point to fix those, but not real soon.
How did you import that turntable into DS?
It's in OBJ format, so a direct import. It also has a 'set' attached...a couple of planes making up a floor and wall, so I deleted them in Blender, first.
