Add to Smart Content
WebsoulWebsoul Posts: 221
edited May 2024 in Freebies
Some freebies have support files but those won't be added automaticly to the content database.
So I made a simple popup box script that can add Smart Content files to your content database.
zip Version 1 (single file)
With version 2.2 you can add a list of support files you want to add to your database, useful if you have an whole library that you want to add to smart content in one go.
zip Version 2.3 (multi file)
Post edited by Websoul on
  • RAMWolffRAMWolff Posts: 10,369
    Sounds useful!  Thanks so much!
  • WebsoulWebsoul Posts: 221
    I noticed this script also works for the Daz products where the image for the smart content is missing.
    When I run the script on those items the image is back, nice side effect of the script :)
  • atoxicatoxic Posts: 155
    Thanks. An useful add on.
  • FenixPhoenixFenixPhoenix Posts: 3,189
    Oh, what a useful script, thanks for sharing it @Websoul! I have a lot of broken thumbnails, so I look forward to trying it out this weekend!
    Sometimes Smart Content is a mystery to me.
    For instance, this product https://www.daz3d.com/kumi-leiko-and-dress-for-genesis-8-females is one of the many products that has no promo image for the smart content.
    I have checked the image name, image size, store name in the metadata and everything looks good so it should work, I even uninstalled and reinstalled the product and still no image.
    I run my script and YAY the image is finally there.
    Restart Daz, and its gone frown
    very frustrating since everything should be working.
    Maybe I should just mail Support with the ever growing list of products without a product image.
  • SofaCitizenSofaCitizen Posts: 2,134
    Do you log into your account within Daz Studio?  If you do then Daz Connect will replace all the thumbnails with it's own version on application launch.  Since these are not stored alongside the DSX files in Runtime/Support but in the Connect cloud folder then Daz Connect will update the thumbnail path in the database to point to this new location.
    @SofaCitizen ... thank you so much. I thought I was going crazy looking for why the thumbnail would not show up.
    That also explains why the thumbnail showed up when I ran my script, at that point it took the support thumbnail untill Daz loaded again and it went back to meta data.
    It seems that several products including 1_74265 have no JSON and no JPG in the cloud.meta folder.
    So When I copy, rename and  paste the image from the support folder to the meta folder the product has a thumbnail so it does seem to get it from there.
    I guess I will just spam Support with missing thumbnail requests since it is an issue with the cloud / metadata side of things and I can fix it for now but in event of a reinstall they will be lost again.
    No worries, glad to shed some light on the issue. Sending a ticket to support would probably be best as I know that Daz Connect messes with any manual changes you might make to DSX files so you might find that your manually added thumbnail gets removed next time you start up Daz because it doesn't match what Connect has on the server.
    Yeah, that's one of the reasons I stopped loging in from within DAZ Studio, images that were there just started disappearing. And I sometimes like to use Smart Content to quickly check what the outfits look like when I'm kitbashing.
    edited May 2024
    This is a new version of the script with a multi select option,
    I ran into the issue that I was adding a new library but the smart content of that folder was not loaded so I wanted the script to be able to run all the support files at once.
    You can go to the Runtime/Support folder of any linked library (it needs to be active in Daz) and select the .dsx files you want to add to smart content.
    It will tell you how many files were added and what files failed to run.
    1202 x 801 - 108K
  • ElorElor Posts: 3,486
    It looks useful, thank you smiley
    (Is it normal that we are seing your mail address as your forum name ? I'm asking because in the past, there was a bug that switched the two)
    Thank you for the heads up, I changed it back to my username.
  • crosswindcrosswind Posts: 9,704
    The script is always frequently-used by me. Thank you for the update ! yes
    edited May 2024
    I have time to try the script today but it didn't work on my side with any dsx file, like the below screenshot... I'm with latest 4.22 GR.
    After adding "Runtime/Support/" prior to the array value of dsx file string into the line of processing metadata, it worked. I'm a script newbie so I wonder how it worked on your side without the string of runtime path. Pls help to check...
    PS: I found that after selecting dsx files, the line item in the list can be deleted (this is good...) but then it still processes metadata of the originally-selected dsx files... So the remaining items in the list should've been added to array list before processing metadata.
    802 x 532 - 21K
    1253 x 882 - 73K
    Post edited by crosswind on
    edited May 2024
    Thank you, yes the "Runtime/Support/" + should be in there and it was one of the last things I had added so maybe something went wrong with saving the file.
    You have fixed it yourself so wont need the newer version but I uploaded the fixed one in the original post and called it V2.1 just to have some versioning.
    I will look into the deleting of the file from the list, will fix that today since I know what the issue is I just need to find a way in Daz script to fix it.
    I am a Daz scripting newbie too so any comments or improvements are more than welcome.
    It was easier than I expected so I have updated to V2.2 so you are now able to delete rows from the list.
    I have added the zip to the First comment in this thread since I think its easier to just update one location instead of all over the thread.
    Oh, yea ! Many thanks!
    edited May 2024
    Made a small quality of life update with version 2.3, if you copy paste a filename you don't have to add the .dsx behind it.
    During processing if the filename does not end with .dsx it will add it.
  • FrankTheTankFrankTheTank Posts: 1,535
    I use Content Package Assist to make DIMs for products purchased from other stores. Unfortunately, even though I include thumbnail pics when making the DIMs they never show up in smart content. Does this script help with that? Or is that beyond the scope of this script? It could just be I am using Content Package Assist incorrectly, but its something I've never been able to figure out.
    Nope... this script just helps with importing metadata rather than creating metadata. I ever helped a folk who used CPA to solve the same issue as you have, pls check this thread - https://www.daz3d.com/forums/discussion/683746/3rd-party-thumbnails-in-smart-content-but-no-files/p3
    edited May 2025
    If I'm installing metadata (ones I created myself) with the script, the Compatibility Bases will not be applied on the items, while its not the case when I'm doing the same with the Re-import metadata tool.
    To explain the process:
    1. Metadata created on my Mac.
    2. .dsa / .dsx files transfered on another computer.
    3. Script used to install said metadata.
    Once I have done that, I can see the product in Smart Content, looking exactly the same as it would on another computer, I can ask Smart Content to show me the addon for one item (let's say a dress) of that product and Smart Content will show me them (material presets in my example).
    But if I'm loading that dress and I ask Smart Content to filter by context, with the dress selected in the Scene tab, Smart Content will not show me the material presets. Checking the scene identification of the dress, it has 'None' as Compatibility Bases.
    Using the 'Set Default Compatibility Bases' tool, I can watch the list of the known Compatibility Bases and the product I just installed appears here, with the corret Sub-root Compatibility bases.
    I tried to import the metadata multiple times with the script: I though that maybe there could be a problem in the order the metadata were processed, so with the Comptibility Bases already created, maybe it would add them to the items,  but it didn't change the problem.
    Does someone know the root of the problem ? Is it a problem with the script or a problem on my side of the screen ?
    Edit: I forgot but in case it's important, I'm using Daz Studio 4.23 PB on my Mac to create the metadata and I saw the problem on Daz Studio 4.23 PB on Windows but did most of my test on an older machine laying around, using Daz Studio 4.21.
    Post edited by Elor on
