Yoga positions ruined by glutes
jamesramirez6734jamesramirez6734 Posts: 90
edited January 2023 in Daz Studio Discussion
When positioning G8 or G8.1 (I haven't tried G9 much yet) into yoga positions, the glutes frequently stand out as clearly un-natural
On the first image you can see the curve is natural to a point, but almost seems to blend into the thigh and become a vertical line too early - it's as if the curve ends too soon.
The second image shows how a glute morph expands the curve, but ends up looking really silly because again it doesn't blend into the thighs properly.
The curve going into the inner thigh is a real issue also, there's no 'fat' where there should be.
Has anyone found any products which can help with this, or whether they've found it's significantly improved in G9?
Post edited by jamesramirez6734 on
  • crosswindcrosswind Posts: 9,625
    edited January 2023
    Zev0's bend control/glute control plus K.H. Image Studio's UNBM2.0 can make it much better. I've been using them together plus tweaking a couple of thigh and glute morphs, the results are pretty natural for most of the cases. There've been no G9 versions of them so far but there will be I believe... so G9 may just need some thighs/buttocks related morph dials for the time being...
    Post edited by crosswind on
