Problem with V4 Elite models
Hi all. I don't know if this has been discussed elsewhere, but I recently purchased the V4 Elite set to buff up my existing V4s, but I'm having trouble making it work properly and I think I must be missing a package somewhere.
The setup as I have it now is V4.2, V4 Base, V4++ morphs and now V4 Elite. All of the morphs (i.e. V4.2, Base and ++) are already injected into the V4 I'm using as a starting point. However, when I inject any of the Elite morphs (I'm trying with Sylph at the moment) and set the dials from 0 to 1, all that happens is that V4's head bloats up to twice its size and I end up with a hydrocephalic basic V4 with none of the morphs activated. What am I missing or doing wrong?
Any help gratefully received :)
(Edit: I'm using Poser 9 with the latest service pack)
Make sure you only have one Runtime with a "Runtime:Libraries:!DAZ:Victoria 4" folder, and that folder must be in a writable area (e.g. on Windows 7/8/Vista it must be outside of Program Files/Program Files (x86)). Then go to "Runtime:Libraries:!DAZ" and double-click on DzCreateExPFiles-V4.bat (.command on Mac), A black window will open and the morphs will scroll by rapidly, then the window will close. Then load a fresh Victoria 4.2.cr2 and that should resolve the problem.
That worked perfectly. Thank-you very much :)
