HDRI help
souravpadhi89souravpadhi89 Posts: 80
edited January 2023 in Daz Studio Discussion
Hi,
I have the HDRI which is used in this picture here:
But, my renders are no where similar to the sharpness and realism of this render. Can someone please help me in understanding the process of using the HDRI correctly?
Attached is my render:
Post edited by souravpadhi89 on
  • The camera angle (Focal length) may be a factor, and I think you need to adjust Tone Mapping too ((using Redner Settings or a tonemapper Options node, which will not be available until after you do a render/PBR preview or Create>New Tonemapper Options).
  • This HDRI is available in several resolutions, up to 20k.
    What resolution have you used ? If you want a sharp image, you must take the 16k or 20k version.
  • souravpadhi89souravpadhi89 Posts: 80
    edited January 2023
    Ohh Okay, All my HDRIs are around 4K or 8K max. Then I will try with 20K and see.
    Update: naah, no use. I think the original photo has been postworked in photoshop.
  • You should see a difference in sharpness.
    Have you checked that the camera has depth of field disabled ?
  • crosswindcrosswind Posts: 9,732
    It seems not HDRI resolution issue, you may change Pixel Filter in Render Settings to increase sharpness, by using mitchell with value 0.7, sharpen enough... Besides, set a lower value of Environment Intensity or Environment Map, the sky seems overexposure.
  • DartanbeckDartanbeck Posts: 21,988
    Sorry for the off-topic, but crosswind... I just love your avatar!!!
    A haha~~ Thanks!cheeky
