outoftouch Hair update galore
Rod Wise Driggo
in The Commons
Well I am used to an updated product every now and then but having approx. 40 updates to Outoftouch hair for various generations in DIM caught me by surprise ;-) And those are not particular small files either.
There were problems with a good number of outoftouch hair in recent versions of DS (something to do with their materials AFAIK), that's most likely related.
Yes, a known problem https://www.daz3d.com/forums/discussion/comment/7944791/#Comment_7944791 (Transmitted Color map)
Is this the final solution? That's 14 GB of content for me to download...
Well since Genesis 9 I have many hairs, not just OOT hairs, that do not stay on the head of the G9 models. Sometimes the hair doesn't fit from the very instant I click the hair preset to put it on the G9 character and sometimes that works OK but when I open back up the scene after closing it the hair has floated off somewhere nearby in space, but not on the head of the G9 character.
Hey,
the updates actually only update the shader file that comes with each hair. Since the shader file is the same with all these updated hairs, you would basically only need to update one hair and have the shader file updated.
What is fixed: There is an issue with how the new Daz Studio Public Beta version is handling a specific setting that was used with these hairs. The renderer crashed and quit without the update. If you do not have issues when rendering, you do not need to install the updates, as this, at least at this moment, only affects the use of the Public Beta version of Daz Studio.
Hope this helps :)
That is unrelated to the crash issue, though. What are problem hairs? Are they dForce Hair?
Surprisingly, here is one of them: Hudson Hair for Genesis 8 Males | Daz 3D
There are others, but I don't want to go through and do all the tests to identify them all as I am working now on Blender tutorials and will be for months on end.
Running Studio 4.21.1.26. I manually installed the new "OOT Hairblending Hair.dsf" shader (the only change) from one of the updates into its place in the library ("\data\outoftouch\OOT Hairblending 2\OOT Hairblending 2 Hair\"). Tried a few OOT hair products and no crashes, no problems. The transmitted color channel doesn't even show anymore. (Just on the cap, which is a different shader). The file modified date I see is 2023-01-05 04:47 (might vary with your time zone).
Was Studio running when you installed the update? It might have the old version cached...
Anyone with the latest beta (4.21.1.29) have anything to add?
I believe you solved my problem! By identifying the single significant file, I was able to search for it and found an old version in my Daz Connect data cloud folder. I don't use Daz Connect any more, but there is some old junk left in there. I suspected Daz Connect as the source of the problem, because of the way it supersedes DIM installations without warning. I had looked specifically for Daz Connect installations of the updated products I had tested which failed, but didn't find any of them there. However, with your help, I was able to find another older OOT hair there that I had not tested since the update. I uninstalled it from Daz Connect and deleted the product from Daz Studio. Then I reinstalled it from DIM. I also purged the DSON cache for good measure. The OOT updated hairs are loading without Transmitted Color now and they render in the beta. Thank you for the critical info to fix this issue. Have I said recently that I hate Daz Connect?
Nice catch. That shader is installed and used by all Hairblending Hair products, so as OOT said, installing one is all you need. Just make sure there is only one...
Not today, no...
I hate Daz Connect.
OK, now today is covered.
Wouldn't touch it with a ten foot pole. I don't hate it but I feel pity for the new users that fall into that trap because there are no warnings about logging in to DS when one uses DAZ Central or DIM to install ones content.
Hudson Hair seems OK for me, in the Public Build.
That was the one that worked on initial preset fitting to G9 but when I saved scene & reopened it, the hair is directly floating over his head. I have DSPB 4.21.1.29. However, maybe it got messed up in the prior DSPB, I can't remember.
Ah, it doesn't say so on the product page and I looked in the wrong place to check but it is dForce Hair and that won't AutoFit because of the way the strands are generated. Check to see if the hair itself (rather than any scalp node to which it attaches) has the Line Tessellation group of properties under General in the Parameters pane - if it does you will get this issue with AutoFit.
OK, thanks. I didn't realize it was dForce hair. I will just delete & readd on scene open. They should figure out a workaround.
On the OOT hairs, if you use Connect, have legacy Connect files with a DIM workflow, or have multiple content directories so that you get an unupdated copy of the hair blending file, find a good copy of the file* and copy it, then execute this script in DS and it should open a file browser to the copy that DS will actually use - paste the updated version over it and the issue should be resolved 9obviously my testing was just on my own system).
* You can get the updated files from the /data/outoftouch/OOT Hairblending 2/OOT Hairblending 2 Hair/ in your main directory if you mainly use DIM, from an updated zip, or you can right-click on one of the updated OOT hair products in Smart Content>Browse to Product Folder and then find the file in there if using Connect.
The holy grail would be, if OOT could decide to add dforce simulations to their (transmapped, polygon) hair products.
https://www.daz3d.com/hudson-hair-for-genesis-8-males
was made by @Propschick and not by Outoftouch.
Hello,
I Just want to seek further confirmation of this for others, before I message outoftouch to make them aware if they are not already. I don't want to bother OOT if it's mere user error.
Is anyone else getting severe highlighting artifacts in the flyaway layer of some hair post update? Seems to be affecting four out of the six I have and showing most badly in lighter colors like blonde and red. I described the issue, recieved confirmation from another user that they were having the same artifacts, and documented some attempts at fixing it in this post:
https://www.daz3d.com/forums/discussion/618601/strange-artifacts-in-out-of-touch-hair
TL;DR - Bright artifacts in some models that weren't there before. Most visible in lighter materials and models with many flyaway strands. Some manual setting changes seem to fix it.
For Reference
Example: December 2022 (left) vs February 2023 (right)
Note: I am using DAZ Studio 4.21 Pro
Thanks, for any help!
If the iems are from the Daz store report them to Daz rather than to OOT - if it is something that needs the PA's attention Daz can then pass it on.
Thanks, for the quick reply! I'll do that.
Do I do that by submitting a ticket through the help center and use the "submit a request" button? I'm guessing the request type would be "technical support questions". (apologies, I've never done this before.)
Edit: I think I figured it out. Ticket submitted.
THis looks like an old issue that's returned. Changing cutout opacity to something like 0.99 or 0.98 fixes that.
I don't ever load DS while my internet is connected because of connect, add me to the list of Daz Connect haters!
You just need to never login to your Daz account from Daz Studio. Then Daz Connect will not be able to download metadata changes or install products. In Preference, go to the Startup tab and uncheck "Automatically Login With Remembered Credentials" and uncheck "Show Login Page". If you are already logged in in your current session, log out.
Thanks, for the info! I had by trial and error found that "cutout opacity" was affecting it somehow, in addition to another user suggesting certain settings that included it, but I was unsure of what values were best. 0.99 does seem to work. It'll just be annoying to have to change that every time on every model until an update fixes it.
Anyone have thoughts on the "thin walled" parameter? It also seems to fix it but the other user cautioned against potential issues with transparency being lost.
I have so many Outoftouch hair but no updates in DIM for me.
I was hoping that the update galore would resolve the color/gloss/glare issue with Caprice hair, but apparently the update does not address that particular issue.
Did you ever get any resolution to your ticket? I just noticed Bendine hair is also doing this. I hope they put out a general fix. I would hate to think I'm going to have to go through all my OOT hair and figure out the problem hairs myself. I have a LOT of them.
edit: "Martha's Everyday Bob" does it too. Ugh.
@butterflyfish
The only response I've had so far was the initial confirmation email of the ticket being submitted. That was about nine days ago. While I'll plan to update my original post if Daz or outoftouch fixes the problem, the confirmation email did mention as follows:
With that in mind, I'd infer that the best thing would be for anyone having this problem to submit their own ticket. Hopefully, enough individual tickets will boost the priority to get these artifacts fixed for everyone.
I'll restate the two manual solutions that I am currently aware of. Both are done in the surfaces tab.
NOTE: These settings are local and must be changed for each model every time a new instance is imported. If the item has an "!Apply First" script, that seems to reset the settings back to the relative defaults as well. While both "0.99 Cutout Opacity" and "Thin Walled On" worked for me, other users have recommended the first option and cautioned against the second.
Anyway, best of luck with yours!
EDIT: I revised the fixes to avoid confusing wording and removed some unnecessary rambling.
