DAZ install manager cannot be run with elevated permissions.
No matter what way can not open DIM, what should I do? Always hinting at this?
You are either right-clicking and choosing "Run as Administrator", or you are launching from a shortcut set to run the application ad administrator. This is now blocked as it was a frequent cause of problems. If Install manager needs to use elevated privileges to install software or a plug-in you will be prompted, you do not need to start the application with elevated privileges.
Having the same problem just installed everything and nothing will run... and i'm not running anything as an Administraotor. DazCentral, DAZ Install Manager, DAZ Studio 4.21... nothing will run it all says the same thing. "Cannot be run with elevated permissions."
I have checked everything and nothing is set to run as Adminstrator it just doesn't work.
