[Solved]Duplicate Formulas - Aging Morphs for G8M
PerttiAPerttiA Posts: 10,024
edited January 2023 in The Commons
I have filed a ticket already, but...
aging-morphs-for-genesis-8-male-s
Bought it yesterday and found that the product seems to have conflicts between the included morphs.
Post edited by PerttiA on
  • frank0314frank0314 Posts: 14,718
    What means did you use to install the product?
    Manual installation as I do with everything
  • BejaymacBejaymac Posts: 1,945
    DF's are normally Bone XYZ linked to Asset ID, and only show up when you have two morphs using the same Asset ID, which usually come from two different products.
    This however is Asset ID linked to Asset ID, which is normally an issue with just one product, could be a DSF file with two sets of identical Formula, could be two DSF files with different names but are identical inside.
    Big question is why it's only showing up now?
  • Zev0Zev0 Posts: 7,122
    What other sets that are similar do you have installed?
  • Which dos prompt the question - are you sure you are using the latest version of the files?
    edited January 2023
    Downloaded the installation file and installed, if it's not the latest version, then DAZ gave me an old one.
    The manifest.dsx and supplement.dsx are dated 2018-05-31, 11:54
    Didn't start tracking down, as the error in the log gave the impression that Aging head controller was having problems with the individual morphs in the package.
    txt
    txt
    Duplicate_AgingG8M.txt
    26K
    There has been cases where files on DAZ servers were not the correct ones, I remember a case where code from one DSF was merged with code on another DSF and it was not what the PA had sent DAZ.
    edited January 2023
    Nevermind... Apparently at some point after the release the Aging Head Controller was created and an older version removed.
