New Piercings Set for G9 on G8?
vonHobovonHobo Posts: 1,711
https://www.daz3d.com/m3dp-piercings-set-for-genesis-9
Will this work on G8?
I'm assuming it won't, otherwise, wouldn't the PA have listed G8 as compatible?
Really kinda confused which G9 hair, clothes, props etc will work on G8 or not.
  • Depends how it's made. If it's static props parented to rigid follow nodes or skeleton bones then it always can be repositioned and parented manually. If it's conforming wearables, it probably can be autofit but it will likely deform on autofit.
  • vonHobovonHobo Posts: 1,711
    Thanks! I keep seeing G9 stuff I would like to purchase, but I'm using G8 figures. Oh well.
    Went from spending $100's every month to like less than $50 ... so that's a good thing.
