Hospital Hallway issue - can someone else confirm?
in The Commons
Hi,
Hoping someone else can confirm this before I put in a ticket.
I have the Hospital Hallway set (https://www.daz3d.com/hospital-hallway)
When I try to load the single prop of HH Bench Type 1, it basically loads and is about .5 mm in size and turned on its side. The HH Bench Type 2 loads just fine, but type 1 is basically the size of a flea. Would anyone else who has this product be able to confirm this is the case for them too?
Thanks.
You're correct. When loaded as part of the set, it's scaled up to 10,000% and rotated on the X-axis by 90 degrees. It's weird, but easy enough to compensate for.
Thank you for confirming!
