DS Adam for Genesis 9 has mandatory anatomical elements?
When you turn the anatomical element off it leaves a patch of skin missing.
How do I fix this?
  • What do you mean, turn off? Geometry Grafts like the Anatomical Elements usually hide part of the model, and it stays hidden as long as the graft is fitted - regardless of whether the graft is itself visible or not.
  • EZ3DTVEZ3DTV Posts: 1,527
    When you hide his elements it leaves a big hole there.
    And there does not seem to be a way to load him without elements or any slider morphs or scripts to have them go.
    Clothing does not cover over them and when you hide them as I said it leaves a big hole in him you can see inside.
  • barbultbarbult Posts: 26,461
    Don't hide them with the "eye" in the scene pane. Unfit them from the character or delete them from the scene.
  • nemesis10nemesis10 Posts: 3,889
    To be more specific:
    1. Load DS Adam
    2. DS Adam loads as a group... expand and note Adam AE (anatomical element)
    3. Delete Adam AE
    4. You are done
    edited January 2023
    1. Load DS Adam
    3. Delete Adam AE
    4. You are done
    That worked fine nemesis10, I did not notice it in the categories.
    Removing it does leave a distortion in the texture field where the element was but it is okay.
    Great character though! smileyheart
    Thanks for the help barbult and nemesis10!
    Post edited by EZ3DTV on
