Line Render 9000
Adruzo
DAZ studio is crashing everytime I try to run [Line Render 9000] this plug in. Is anyone else running into an issue with LR9K ?
It isn't a plug-in, its a collection of scripts and shaders. What steps are you using? Are you getting any errors, or a crash-report duialogue?
In the Product's folder: in the Content folder inside the Read Me folder there's supposed to be a PDF that may or not help.
Thank you for the correction Richard. When I try to run the LR9K script Daz studio crashes after a partial completion of the render. I am getting an error, but I do not remember the specifics.
I can tell you that the error will not let me report it as the report window is greyed out for some reason.
Please check the end of
%appdata%/daz 3d/studio4/log.txt
after the crash (Windows path) - it may not be helpful, but with luck at least the last error to apepar on screen will have been written to it. Failing that try again and take a screenshot of any errors or pop-ups.
After I click the render button, The render starts as normal then at about 80-90% DAZ studio crashes and I get this error.
See attached.
I figured it out.
The problem was, as usual, my fault. I had two hair wigs on the model and the system DID NOT like that one bit. When I discovered the second hairwig, I removed it and retried the render, POOF like magic it worked.
Thank you Richard Haseltine and Catherine3678ab for your input and assistance it is much appreciated.
