texture problem with victoria 9 HD (Solved)
PsyionPsyion Posts: 12
Hello,
when I render with victoria 9 hd, I get marks on the character. A bit like if the character had a garment with straps.
I work with daz 4.21.0.5 pro edition(64 bit) under windows 10.
If you have an idea?
Thank you for your attention
Post edited by Psyion on
  • MattymanxMattymanx Posts: 6,998
    Re-apply the skin texture from the Material folder.  It looks like one of the sections on the surface tab is either off or the image got removed on the body surface.
  • PsyionPsyion Posts: 12
    Thank you Mattymanx, I tried but no results. I uninstalled Victoria 9. I did an update of genesis 9. I reinstalled victoria 9. I always get the same result
    Hello,
    I found the solution. I have uninstalled victoria 9 and genesis 9. Then I reinstalled genesis 9 and then victoria 9. The problem is solved.
    When I bought victoria 9 I installed it without before genesis 9. When I wanted to use Victoria 9, a message told me to install Genesis 9. After installation I had a texture problem.
    Thank you for your attention.
