Mimic PZ2 to Genesis Converter
I have written a stand-alone program to convert PZ2 files generated in Mimic using Victoria 4 (the only figure that I can get to work properly) into files for Genesis, Genesis 2, Genesis 3, Genesis 8 & 8.1 and Genesis 9, in DUF format.
Unfortunately the sound file is not included in the new file and has to be added manually.
There are 32bit and 64bit versions included.
These are Windows only.
  • wsterdanwsterdan Posts: 3,578
    edited November 2022
    Which "Mimic" are you using?
    .dmc files for Mike/Victoria 1-4 and Genesis-Genesis 8 already exist and all appear to work using DAZ Studio 32-bit lip sync.
    A .dmc would be very welcome for Genesis 9, though.
    Post edited by wsterdan on
  • jdfoxjdfox Posts: 38
    I'm using Mimic Pro and Studio 64bit, but I've never obtained a satisfactory lip sync with genesis 1-8 .dmc files provided. I generate a pz2 file using Victoria 4 and then use my program to convert to a Genesis .duf file.
    Ah, thanks for the info. I've been using the 32-bit lip sync built-in, but maybe I'll reinstall Mimic Pro and see how it holds up. Asmy Mimic Pro's only 32-bit, it'll have to be run on one of my older machines.
    thanks
  • mindsongmindsong Posts: 1,788
    hi - mimic pro should work fine on any win64 system. I use it on win10 64bit home regularly without issue.
    (and thanks to the original author for this treat!)
    --ms
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,512
    this sounds great as the lipsync is definitely inferior to Mimic generated animation
    I do use the Carrara Mimic plugin but I only can export the bone movements not the morphs with it as BVH for studio they do however work on even Genesis 9 especially which uses the bone based FACS
