Anyone know of an easy way to create tapes (name tags) for Insignia Expansion for ATLAS Armored Suit
I searched the forums and could not find anything. My Substance Painter is not working at present, driver issues, and I do not have any fancy editing software. Just wanted to know if anyone had any luck with this.
Thank you,
Sigurd
  • SofaCitizenSofaCitizen Posts: 2,105
    I don't have that product but looking at the Promo images it would seem that these are just simple images for each of the supplied names. So you can just create a new similar image in any graphic editor and swap that out on the currect surface?
  • SigurdSigurd Posts: 1,094
    I just got my Substance Painter to work (have not used it in awhile) and I will try that. Thanks for your advice, if anyone else has any experince with this, I would also welcome that advice too.
    Thank you all, this is a really helpful community.
    Sigurd.
    Sigurd.
    Hi, as for editing software(for graphics/textures) if you do not have one, you can go to photopea.com and it is free. Basically photoshop. You can even use your brushes etc in it. I hope that helps a little.
    Thanks, I will give it a try on my next day off.
