Can I change this Wounds Colors?
foxyfoxfurries
I really like to use this : HD Face Wounds for Genesis 3 & 8 Female(s) | Daz 3D
But when I put it on my model I want it to be more red and not that dark , May I change it some how or it is how it is?
Thanks so much! :)
The materials are LIE, so you can go into the LIE manager and adjust the layer with the wound.
Thank you very much , but where can I find the LIE manager?
Click on the image surface tab and select *Layered Image Editor*.
Thanks but I click on the surface tab and didnt found Layered Image Editor , I also want only this blood to get more red , I click on the Surface and i'm in the edit but I dont see the blood. If that's what you mean
You need to click the nano-thumbnail for the current image assigned to the property you want to work on, to get the list of available images, the browse... command for llading new images, and the Layered Image Editor command.
Sorry if I didnt get it right I try to understand , I need to put the layer on my model and then do it , or I need to do it on the image layer before I put on my model?
The idea behinf LIE is that you can change it inside Daz Studio. LIE is a simplified image editing function.
An alternativ is to take the image into an image editing program and adjust it there. If so, you must select 'browse' and then browse to where you have saved the modified image.
Thank you felis , I know how to change images and colors but I dont know how really change the LIE because its kinda hidden , Step by step even in write may help me if its possible. You all really help me a lot and I even try it again now.
FenixPhoenix It will be help a lot for me! Yes I want to make the blood more red and less darker :)
Ok, there are two things you can do.
Edit the textures directly:
Now if you don't want to mess with the textures directly and you prefer to do it inside DAZ studio, here's what you can do (though it will be a more complex process):
You have to keep in mind that LIE is difficult because as an add-on product, we can't control the skin settings. We can only include maps in the channels where maps should normally be included and hope for the best. Our LIEs are mostly done taking into account how DAZ Core Characters have their skins set up. So for PA character skins that are set up differently, you'll have to experiment to get the best result.
In the case of my example for Pei, her skin is set up quite differently, so I'm getting a dry look for the wound right now, as you can see in the before and after below:
This is also why we ditched that approach with the Gunshot Products and went with Geoshells from then onwards. That way we could control how the wound would look and it was a more straightforward application of LIE, since it was only applied to the cutout channel.
I can't seem to upload my screenshots, so I'll upload them someplace else and edit this post to include them in a bit.
WOOOOOOOOOOOOOOOOOOOOOW Thank you very much for the amazing guid! I thought its simple to do but I will still try it out!
Now I sure I will succed I will work step by step with your pictures! Thank you very much!!! Your AWESOME!
@foxyfoxfurries you're very welcome, thank you for buying our products! If you have any more questions, feel free to reach out :). I encourage you to try the different blend modes to figure out which one works best for your character. BTW, you could always also use a texture/photo editor program (like Photoshop) and apply the maps directly onto the skin maps of your character, save them as something different, and then replace them via the surface panel. For Face Wounds you only have to apply the textures to two maps: The Specular/Roughness Map and the Diffuse/BaseColor and Translucency map (which are sometimes the same or very similar, with Translucency --also sometimes known as SSS-- usually being a lighter version of the Diffuse map.
Thank you very much! I have more question I did what you said But its still little dark but now looks more good. Have more way to make it more red?
And when I do this it wont damage the girl face or body skin right? Thanks :)
https://ibb.co/sVs8jvs
https://ibb.co/RBtPfSH
To answer your question, yes, LIE won't damage the skin because you can always take it off. If you have any of the body wound products, there's a LIE Remover script there that you can apply here as well to get rid of the LIE layers. Our Makeup sets also include one. At any rate, I'm uploading the script here for you to download. Just merge that with the DAZ 3D Library where you have the product installed. Then you'll need to use the Content Library Pane to access it. The path would be: People\Genesis 8 Female\Materials\FenixPhoenix\Face Wounds.
Now, in the following example, I'm using Millawa 8's skin (ignore the blue lines in the screenshots). First off, we'll be once again using the Layered Image Editor, but we'll try a different combination of blending modes and we'll also edit the first layer of the diffuse. So, on the surfaces tab, open up the Diffuse/Base Color Map in the Layered Image Editor after applying the wound. You'll want to change the following:
Next, open up the Translucency Map in the Layered Image Editor and change that to the following values:
That should give you a result like the following:
Now apply the Matching Blood LIE and once again you'll want to edit both the Diffuse/Base Color and the Translucency maps via the Layered Image Editor. You can do all of it at the same time by applying both the wound and the blood one after the other before messing with the Layered Image Editor. I did it this way so it's clearer when I explain. Anyways, you'll want to change those maps with the following values:
And this should be the result:
Your awesome I will try it out! Your guids really help A LOT! I really hope you will make more good bloods in the future I will buy it for sure I have few stuff your selling and all of them work so well :)
Thanks for the assisting and helping! Your awesome! :D
