Geoshell on Genesis 8 figure loses conformity when the figure is moved to a new location.
When a Genesis 8 figure with a Geoshell is moved to a new location, the Geoshell loses conformity.
Screen-shots attached.
How can this be resolved?
  • felisfelis Posts: 5,880
    try to change instance optimization to either Memory or Speed before rendering.
  • CA415CA415 Posts: 165
    Thanks for your feedback.
    This appears to be a Viewport bug that occurs under both the 3Delight and Iray render engines.
    But have you tried to render, after you have changed instance optimization?
    I don't use the Iray render engine, and Instance Optimization only applies to Iray.
    To my knowledge, there is no equivalent in the 3Delight render settings.
    Thanks, again.
