3Dlight issue
rkcollirkcolli Posts: 1
Hi All-
After rendering a simple scene with just one prop, this error keeps generating; done the usual from restarting daz to rebooting the machine; looked over cameras and lights, and even cleared the Temp directory too. Also switched props/figures and I'm getting the same results. Not sure what to do with it, anyone out there run into this one too? Looked through forum and did not find a direct match. Any help is appreciated!
Best Regards,
TJ
  • Richard HaseltineRichard Haseltine Posts: 109,355
    It's not an error - it's telling you that there's a surface with displacement set on but no actual displacement. If you were making a film you'd probably want to adjust the settings so it didn't waste time with unneeded calculations but it's not a big deal, especially for a still image.
  • rkcollirkcolli Posts: 1
    Thanks for the tip! Interesting; maybe I have two things going on then because the render frame is totally empty, the render engine throws the message after it is finished.
