HDRI scaling
I've noticed that a lot of the background HDRI files I've purchased are not scaled to work with the standard sized Genesis figure (see attached pic).  I've tried adjusting everything in the environment tab... finite sphere, dome radius, dome multiplier, etc... But nothing seems to help. The only thing that's even come close is scaling my Genesis figure (and everything else I add to the scene) up by a factor of about 500 in some cases.  Isn't there a better way?
  • Camera settings would need to match those of the camera used to take the original iamges, but a factor of 500 does seem extreme.
  • bicc39bicc39 Posts: 589
    If I may.
    Render both separately, combine in Photoshop
    To be accurate make sure the render of the HDRI image is the same as cast the light
