G8.1 male hand pose control messed up
AbnerK
Hi, I posted about this before and I thought I'd fixed it because when I loaded G8.1 male he looked fine for the first time in a long time. Sadly the pose controls are messed up and now they dials don't work as expected. So, as I just did a clean install of the G8 essentials on my internal. Can I copy those to my external and fix it? If so, what do I need to copy over? I might be able to work it out but, for now a quick look nothing seemed obvious. Naturally I don't want to accidentally replace my person morphs and dials. I'm more used to macs where merging can be risky if you choose the wrong option. I've deleted directories before doing it wrong.
Thanks.
looking around again I found the file path in the Parameters pane. I'm going to try copying it to my external.
Documents\My DAZ 3D Library\data\DAZ 3D\Genesis 8\Male\Morphs\DAZ 3D\Base Pose
once I found the hand dials in DIM I could reinstall them and the problem went.
