bug
And where should I provide info?
Also where do I get the info from if it's required
I arrived home about an hour ago, and started the render - it definitely has not been running longer than an hour; the 23 hours just appeared.
Should be fixed in 4.8.0.15; see
http://docs.daz3d.com/doku.php/public/software/dazstudio/4/change_log.
Bug reports are submitted to the help desk;
https://helpdaz.zendesk.com/tickets/new
Set the contact department to Technical Support, and if you are using the beta I suggest adding DS Beta to the subject line though that isn't required.
