Weird feet lines on Genesis 8
Hi! I have made myself some custom feet morphs for Genesis 8 model, I also have used "Real Feet" (pack) and "Yujin" character, but sadly I get these weird lines on the feets. I've made two render to compare and its the same for the "Genesis 8 base" model weird lines but a little bit more vanished. Any idea what made these lines show up? Is it just a G8 bug?
  • evacynevacyn Posts: 989
    Are you using a displacement map for the wrinkles? Maybe try removing that and any HD morphs and see if it goes away. I don't see them really on the base G8.
  • felisfelis Posts: 5,905
    It looks like a normal map with too high strength setting.
    I've checked if is from the displacement map and is not. The first time I saw them was when I tried to sculpt the feet morph in blender.
  • StarkdogStarkdog Posts: 176
    The most obvious answer... they were in the bathtub too long!
    Other than that, either the bump map/normal map is too strong, or the foot morphs are too strong.  Might want to check the hidden dials to see if a morph is over-blown.
    Thx I will check it out and come back with an answer.
