Problems saving a wearable
michaelolsonmichaelolson Posts: 117
I'm sending a shirt that I bought from Daz into Hex to make some changes. I am then importing it back to Daz and making it conform to the Genesis 2 model by using the transfer utility under assets. When I try to save it as a wearable preset it says I must parent it to a figure. When I do that I can save, but when I start with a new figure and look in my library and click on the shirt to load it, nothing happens. Anyone have any suggestions?
  • Design Anvil - Razor42Design Anvil - Razor42 Posts: 1,250
    If you are reimporting and refitting the shirt you would need to save the item as Support asset/ Figure/prop before saving a wearable preset.
    This will create a forward facing file to load it and the data assets needed for the shirt.
    A wearable preset is for loading an already saved prop or clothing piece in a set parented position to a figure.
