General 3d modeling question specifically involving Displacement Maps
I'm asking it here in the Hexagon subforum because (doy) Hexagon's a modeler.
If you apply a Displacement Map to a model, is there a way to export the model WITH the Displacement Map applied to it?
(I don't mean exporting the model with a Displacement Map *texture* applied, I mean exporting a model with the geometry having been modified BY the Displacement Map. Like when you apply, say, a detailed Celtic Cross disp-map to one of the sides of a plain cube--is there a way to export the modified cube?)
nope, a displacement map is just that, it tells the renderer to displace the poly's based on the map -- like a bump map except it displaces the poly's on the fly. the higher the poly's, the smoother the displacement map. if it's just a single face, then no actual displacement will take place. you can however, use a program like sculptris, with its brushes, to create geometry from flat images/bump maps, and that will physically displace the polygons of a model, permanently.
displacement is often used as a trick to save resources.
Hexagon's a bit confusing here, it has displacement painting which does affect the geometry of the object and can be exported.
The function of the displacement brush that allows the user to add to the built in displacement maps, also allows displacement maps to be applied to an entire object. Its kind of an undocumented feature.
There was a thread here a while back that described how to do it, but I have not found it yet.
I posted an explanation, but if I can't find it I'll upload the images again.
I could not find the old thread, so here are the images. To use displacement mapping (or texture mapping) the object must be UV mapped first. I don't explain how to do that here. I have used a flat grid as an example, but it will work with other objects.
Also note, the objects needs enough subdivision to be able to show displaced details.
So if I'm looking at that correctly, you click "Validate" after applying a disp. map to the object in order to basically rasterize the newly-displaced object?
That's actually very helpful! (Because trying to do it using the contour feature in Metasequoia is a total pain, and super hit-or-miss)
Are Transparency Maps able to be rasterized in the same way?
After you change the map and click on the flood fill/paint bucket, then click "Validate " and the displacement map will be applied.
Regarding transparency maps, although I have not tried them, I expect they could be applied in the same way.
for me, I have to adjust the alpha mask rather than the displacement to get the desired result.
