Released - Advanced Material Converter * commercial *
2»
  • TotteTotte Posts: 14,797
    Update uploaded - thanks for reporting, was easy to find when I knew what to look for.
    / Totte
    If you just just run AMC Shader Config, it will create the folder correctly and then AMC Converter works.
  • Ghosty12Ghosty12 Posts: 2,080
    edited December 2022
    Love this product, as the one thing I had issue with converting some older products to iRay they grass would not come out right. AMC does a fantastic job of this and many other parts. As this image shows two of Dreamland Models City Block series in iRay using AMC. laugh
    1050 x 650 - 568K
    Post edited by Ghosty12 on
    If you take a look at how the grass is setup, you might be able to setup your own cutom Shader Defintion with AMC Shader Config just for that material zone
    The update is now live
  • GranvilleGranville Posts: 697
    edited January 2024
    This looks great but when I run it, the shaders are still labeled DAZ Default RSL
    Could this be because I am using a custom folder off the C: Drive? Is there a particular base shader that I need to add to my custom folder?
    Why do I not just use the default DAZ folder? Because my 30,000 products would not fit on my C: drive
    1917 x 1023 - 750K
    Post edited by Granville on
    edited January 2024
    Hi, the converted results are stored in a folder named Iray in the directory where the old items are.
    And if you dont see it, rightclick and do "Refresh" so the Content Library list refresh with the new data.
    Post edited by Totte on
    edited January 2024
    Thanks, I figured it out. It does such a good job! I couldn't believe how good the emmissives converted. They were at just the right luminance. I read the whole manual. It's pretty fricken amazing. I'll post a render soon.
    One question lingers. In your experience, what is the most efficient way to handle a multiprop?
    Usually there are both single props and  multi prop. When I change the materials on the single props, I set it using the "Set All", but with care.
