Hard light edges on skin/geometry - G9 (Solved)
linkinbnulinkinbnu Posts: 18
Instead of trying to explain I'll just post a screenshot to show what I've been encountering, never seen this before G9, and nothing changed in my usual lighting setup from G8.1 to G9. I've had a worse occurrence than the one on the screenshot but unfortunately i didn't saved.
Vic9 textures with a different skin texture, Render SubD 3.
Post edited by linkinbnu on
  • hansolocambohansolocambo Posts: 649
    edited December 2022
    Maybe start by stating what "different" skin texture you are using. This is the only thing that seems important and yet you don't specify it.
    P.S : I personally don't understand what "Vic9 textures with a different skin texture" means.
    Post edited by hansolocambo on
  • linkinbnulinkinbnu Posts: 18
    Maybe start by precising what different skin texture you're using. It's the only thing that sounds important to understand the problem.
    I'am sorry, i realized now that i worded it pretty badly, english isn't my main language.
    It's Vic9 maps (normals, etc) and changed the base/diffuse textures to another one from another model.
    The only changes to the main Vic9 maps settings i did was: Translucency = 0.90, Transmitted Color = .95, .45, .55, Transmitted Distance = 0.15 and SSS Direction = 0. I did try to revert it back to stock settings to see if it helps but it didn't.
    Thanks.
  • felisfelis Posts: 5,943
    Does it show with the default Vic9 textures?
  • It's a well known problem that occurs when the mesh resolution is low or the bump or normal maps too high.
    If it happens at SubD 3, try to reduce the value of bump or normal map.
  • Here is an example with G8.1 and Victoria 8.1 HD material.
    Left :
    Body : default values, Normal map 1.0 and Detail enable ON
    Panty : Bump map 1.0
    Right :
    Body : Normal map 0.3 and Detail enable OFF
    Panty : Bump map 0.3
    1578 x 640 - 263K
    It does, first thing i tried and still happened.
    Yep, that's accurate, did some tests (attached) and it's the detail maps that are the problem, it also makes sense I never seen this before g9 since I tend to use normals and bumps very softly.
    I'am a bit confused on what to use, but i'll go with what looks the best.
    Edit: Ended up using detail = .25 and normals 1.
    Thanks for the help!
    1200 x 300 - 330K
