Can't find the cameras for SOA2 By Night *Solved*
Tako Yakida
It's been a couple years since I used this set and now it seems the cameras are missing. I even redownloaded it but no cameras are to be found.
Per the product page https://www.daz3d.com/iray-ds-lights-streets-of-asia-2-by-night it should have 16 cameras.
Any ideas?
Thanks in advance.
Post edited by Tako Yakida on
When I can't find an item from a product, I manually download the zip, unzip it [don't reinstall it] -- but look inside the folders for where the required item(s) is{are} parked ;-)
Thank you Catherine. Still no joy. Not one mention of Camera in any of the folders. :-/
Oh dear, okay ... I don't have that particular set but do have some others ... open D/S fresh {fastest way to clear the scene it seems}, Load the "full scene" it offers. Then in that scene, on the scene tab, hopefully you'll see a bunch of cameras.
If you do, then select those cameras {all of them} and make either a camera preset or a scene subset {whichever works best} of the lot {all cameras}. Double check that those are working as desired. Then make individual cameras presets if so desired.
Dreamlight has a habit of cramming everything into his presets. From the ReadMe, there are only three files in the product. One of them must have the cameras.
Thank you Catherine and Northof45!
Yes, I found the cameras in the Light preset! Whew!
Much appreciated!
