Grainy Render
Hi, all of my Iray Renders are looking very grainy. You can really see it on the skin. I have rendered in Iray before and have never had this problem until today.
What would be causing this?
Thanks in advance for your help!
  • Is the render using CPU or GPU? Which version of daz Studio, and which driver version and card (assumign you have an nVidia GPU)?
  • jbowlerjbowler Posts: 847
    Given the picture I would guess that you are using progressive rendering with the default settings, which terminate the render at  "95% convergence".  My understanding is that 95% convergence just means that 95/100 of all the pixels in the image have reached their final value.  So when you render a large image with nothing in it you start of with a very high initial convergence.
    I suggest just setting the "convergence" to 100% to see what happens.  If it takes a long time (well, too long by your definition; my renders start at 8 hours), if it takes a long time reduce the "render quality" from 1.0 to 0.1 and tweak it up as required for the quality you want.
