How to get G9 eyes looking at the Camera ?
Petra
in The Commons
There was a script, I think a free one, that when clicked made G8 look into the camera.
Sadly, it does not work on G9.
I wonder if any of you might know how to achieve that?
Look At Me II by Riversoft Art has G9 support https://www.daz3d.com/look-at-me-ii-pose-control
I've always just pointed both eyes to a camera using eye's "Point At" parameter setting.
1. Select G9 Head
2. Scene tab, select Left Eye, shift select Right Eye so both eyes are selected.
3. Go to the Parameters tab, with both eyes selected, set "Point At" parameter to a camera.
If the eyes are not pointing to the camera after setting the "Point At" parameter, just nudge the camera and they should point at that camera.
Thank you so much Platnumk and Lindsey.
This really does help.
Yay, it works like a charm.
Thank you so much for your help.
deleted
Never had that problem.
The trick is to select "All" after having selected both eyes, otherwise the "Point At" is only activated for one eye.
Thank you, I will remember :)
I tried it quite a few times and did not encounter the problem you are describing.
deleted
This is such a big thing when rendering stills for portraits why is it not baked in?????
You mean, selecting everything in the scene tab?
No. Select the eyes in the scene tab and then in Parameters tab, select "All", which is above "Favorites" and "Currently used"
Oh cool, I never knew that was there. lol
Look At Me II Pose Control | Daz 3D
This was updated for G9.
Look at camera and Look at each other are the two functions I use the most.
