Strange GoZ and Photoshop Bridge behavior in DAZ Studio
abe01
After a fresh Install of DAZ last Beta, including GoZ, the option File -> send to ZBrush isn't available when DAz Studio is loaded.
The option Send to ZBrush in Daz is only availabe if ZBrush 2022 is started and a 3d Brush is painted and send with GoZ from ZBrush to Daz Studio where DAZ Studio will be loaded. Anybody have this behavior too?
Post edited by abe01 on
Screenshots, there is an issue with the Photoshop Bridge too.
The GoZ bridge may be isntalled in only one release chanel at a time - General release, Public Build, Publishing Build, Private Build. If you install the Public Build and its GoZ the GoZ for the General Release will be removed.
the OS is a fresh Win10 installation and DAZ and GoZ are the latest beta. there is no mixture between the DAZ releases.
Why even bother with beta's if you need to get work done? All you're doing is to make things more difficult for yourself. No offense intended but IMO you shouldn't use beta's if you can't manage to resolve situations like these on your own.
Also because... what guarantees do you have that this isn't caused by a bug somewhere?
Just use release versions and you can mostly rule out the bugs part.
