Crash on Iray Render
Hey folks. I'm having a consistent issue where daz crashes on render. I can render the scene just fine if all characters do not have clothing or poses. As soon as I pose them and add clothes and try to render in iray it crashes.
Log file is attached from the last render.
There are some plugin errors in the log but, I spot checked a few and they are there. Any ideas to help me out?
Iray viewport as well, or Iray render only ?
Often, crashes are due to one item only. Only you, through a process of elimination can investigate the issue. Load the objects one by one and Iray Preview them in the viewport until you've narrowed it down to the item that's causing the issue.
Then share here the name of the Daz bundle you're using, and maybe someone'll have that same bundle investigate on his side and hopefully provide a solution.
