Nano suit for Genesis 2 Males only renders the suit color as black
I purchased the Nano suit for Genesis 2 Males. but no matter what color i select for the suit , when i do a spot render , it always converts to a black suit. the only time my selected suit color even remotely shows up in the render is when i apply the suit glow option. the suit itself will not render the color i select. Any help , please?
Post edited by brian.bole77 on
It may have a custom 3delight shader. Click on an area of the suit with the Surface selection tool (Tools menu), then go to the Editor tab of the Surfaces pane. The sahder currently in use will be listed at top-left, above the list of nodes and surfaces. What is it showing for the shader? If it isn't one of the standard 3delight shaders, or an iray shader, then it will not be given useful values on rendering with Iray.
