Foot Pose Reset
How do I reset the foot pose so its flat on the ground after trying on a pair of shoes, especially high heels, and then deleting them.
The foot stays in the tip toe position.
I've used the Edit / Figure / Zero Selected Item(s) Pose after selecting each foot, but it does nothing.
Post edited by vonHobo on
Some shoes with their particular pose have a dedicated "Reset" script in their folders. Also you could try to mark the each foot in the scene tab, right click on it, hit "Select -> Select Children" and then "CTRL E"
Maybe the shoe item changed the default value on the foot bones from 0 to something else. You can check that by selecting a foot and click on the wheel at the "bend" slider, then "parameter settings".
Also check the metatarsals and toes, those could have been changed as well.
P.S. I hate it when clothing items mess with the character settings...
Thank you. I will try CTRL E.
I looked through all my shoe items but could not fine anything for a reset pose unfortunately.
That was the first thing that I checked but the foot (feet) bend setting is 0.
Check the parameter tab for active morphs. I have a few high heeled shoes that add and set a morph to shape the foot into a high heel base rather than posing the foot. If that's the case you need find and zero the morph.
ciao
TD
thank you
none of the solutions worked, and there don't seem to be any active morphs.
i ended up dialing back metatarsels bend to 0 on one foot, but the other foot was 0 already, so i had to bend the foot up to get it to lay flat
I wish there was something that was an easy fix for this stuff. I could probably zero the entire pose and that would work, but I just need the feet to not be on tip toes.
