skin change when added to a room
cm152335cm152335 Posts: 421
I noticed strange change depend of the scene,,
There is the story,
I created two girls with visually good skin, (white skin close to natural)
In creation of those two girls i do some test with or without lights and result on my eyes was good,
Now, I load room scene and then i insert my two girls in the scene (via merge)
I do a test render and there,,
- The two girls render with different skin result, One become almost burned by sun,,
The other show more white and some reflection (like wet) and no any girl show natural skin like I created!
I check all lights, ,,,
I deleted all lights and created new,,
I check if any shader are done with scene,,
I check the SHOW HIDDEN,,
- - - - nothing found,,
! Always the render was bad result on skin !
There is why I am turn to crazy!
- I do some more test,,
The same girls in the same room scene,
but first I load the girls and then I merge the scene room,,
Skin created of girls was correct! Without change any light!
Why this?
Why rooms without any shader or any specific effect affect the skin?
  • cm152335cm152335 Posts: 421
    edited March 2015
    there is a visual example of my problem
    i put as attachement and link to my FTP
    http://home.scarlet.be/magic_touch/daz.jpg
    the scene is same, not any change at lights or any other effect, just load and merge
    - left, the girls are merge to the room
    - right, the room is merged!
    1242 x 810 - 634K
    Post edited by cm152335 on
  • Richard HaseltineRichard Haseltine Posts: 109,399
    The camera has also obviously changed between the two. Are you sure the lights (and cameras) are not being replaced when you merge the scene? Also, note that render settings and environment settings are saved with the scene file - if oen has gamma 1 and one has gamma 2.2, say, that would make a noticeable difference (as would the setting of the gamma Correction button).
    edited March 2015
    i have no camera, just perspective view
    the change is due because i try to catch same picture but i had no save previous set or pose!
    just move my view and take render!
    i try different view ,, renew the light,, result is same
    is depend in if i "load" the scene first or "merge" scene after girls
    in the two previous picture the scene and the girls have no change juste load/merge
    and i try this several time to check if this is permanent problem
    the problem is permanent,
    always girls "merge "into the scene affect their skin saved
    after the render,
    i deleted the room completely, (include lights) and keep only the girls, the render is same,
    some skin parameter is not take into load when i load the girls after the scene room
    note1: some part are not affected and keep saved preset (e.g. teeth, nails, eyes)
    only the "SKIN" of booth girls is affected,,,
    note2:
    the right picture is more correct (for me) girls are show as they are saved!
    could be more better result playing with lights, but the problem is, - why skin are changes with MERGE feature!?
    note3:
    F2 preferences, scene load, all options are 'IGNORE'
    picture show the girls 'saved'
    without any light or any other effect!
    765 x 873 - 156K
