Problem with obj files in daz
Rudi1967Rudi1967 Posts: 103
edited March 2015 in Daz Studio Discussion
Hello all
I have a little problem with a ring I am working on:
I have the obj file, done in silo with materials applied and I imported it to poserPro. It is perfectly working in Poser.
Now I tried to make a duf file from the poser runtime in daz studio. I click on the poser prop icon and the ring appears on the scene, on the right place but with geometries not complete.
If I import the same obj file directly into daz studio all the geometries are complete.
Does anyone has an idea where this problem is coming from and how to resolve it without importing and texturing and placing this file on 10 fingers.....
I have a couple of other rings which works perfectly in both programs, it's the only one who will not working how I want...
Thanks for your help
Post edited by Rudi1967 on
    Are the three missing inset pieces individual parts or separate material zones?
    If they are separate materials, the actual geometry may be coming correctly, but the opacity may be zeroed out.
    If they are the same material zone as the two that show, then I'm not sure what's up...unless they are scaled wrong.
  • Rudi1967Rudi1967 Posts: 103
    Hi,
    thanks for your fast reply. It was effectively a problem with opacity. I checked this and decided to add real daz shaders and now it's ok. Sometimes you think in a difficult way and the answer is sooooooooooooooooooo simple that you dont see it.
    Thank you !!!!!!
  • danieldarknetdanieldarknet Posts: 21
    I was using daz usually when I add my clothes model the following happens when I add a piece of clothing she will more normal when I add another piece it replaces the one I had already added, it happens to all models, as I resolve that someone can help me please, since reinstalled the program and zeroed the record further still with this problem ??
    Sorry for my English I am Brazilian
