Gallery Albums - Can't Add New Album
Hi All - I am trying to create a new album in my gallery but I am running into an issue. From my main gallery page I click edit, and on the next page there is an option to add an album. I click add and create the album and it appears to be there, but it's empty. From there I've gone into each artwork I want to move to that album, clicked on edit and at the bottom selected which album I want that art to appear in. All is well, but when I return to the main gallery page after saving, the album fails to appear... I mean, it all seems so self explanatory but I do not see any place to publish the album. When I go back to edit the album is on the edit screen, empty, with a gray box which says choose or drag a new image for a new page here... I mean, what am I missing??? Any ideas? Thanks in advance.
  • DAZ_ann0314DAZ_ann0314 Posts: 2,876
    edited December 2022
    Below you will find the steps to creating your new Album. Hopefully this helps heart
    Step One:
    Go into Edit and then Click Add New Album
    Step Two:
    Click where it says "New Album" and then type in your new Album Name.
    Step Three:
    Once the Album is named as you would like, click Save Edits at the top and then go down the page and click on the "Choose or Drag new image for a new Page here..." box
    *Sometimes if you don't put an image into the new album on this page first it will not be able to see the album to add other images or move images to the new Album.
    **You can always use a temporary image if necessary and then delete this image again later once you have your other artwork in the album
    Step Four:
    Next browse to the image you would like to add and then once added, click the thumbnail of the image to go into the Images Page
    Step Five:
    Next be sure to go into the image and fill in a Page Title (Required), Description (Required), and any other additional information. If you look where it says "Album" it should all ready have the new album listed. Be sure to Save and then hit Publish (Very important step)
    Step Six:
    To double check that everything went ok, click on one of your other albums and then back on the new one to verify its there, working, and shows the image you added to it.
    If all is good, then you should be good to go to now go into Edit and change the Album on the other images (just be sure to hit Save)
    Please let me know if you run into any problems or have any additional questions smiley
    1559 x 900 - 76K
    1555 x 471 - 59K
    1567 x 900 - 79K
    1544 x 868 - 193K
    1605 x 952 - 1M
    1644 x 823 - 227K
    Post edited by DAZ_ann0314 on
  • It worked! Thank you thank you!
    You are very welcome. Glad to hear you got the Albums working! Have a wonderful day! heart smiley
