mcjSlideshowVideoMaker - Present Your Renders as Videos Fast! (Update ‎Feb 07)
mCasualmCasual Posts: 4,607
edited February 2023 in Freebies
HISTORY
February 7th 2023 - This is an exact copy of the Jan 4th version, but the sort order of the images in the images list is now alphabetical instead of by creation time,
so it will work fine for numbered image filenames ( as long as they are zero-padded like what Daz Studio makes )
Jan 4 2023 UPDATE
mcjSlideShowVideoMaker_January_‎4_‎2023
That's the version i've been using and improving in recent weeks
example:
- November 9, 2022 01:58 AM fixed the path to the makeStSlideshowVideo
which was getting stuck to the location of the first makeSlideshowVideo.bat
path and filename that you created. Though doing a factory reset was a workaround
- ‎November ‎7, ‎2022, ‏‎6:07:28 PM Fixed the [Run MakeVideo.bat] button
- ‎November ‎5, ‎2022, ‏‎7:18:59 PM Released
The Link : https://sites.google.com/site/mcasualsdazscripts10/mcjslideshowvideomaker
A while ago i published mcjFrameMaker which lets you create decorated frames with a title at the top and signatures/credits at the bottom
https://www.daz3d.com/forums/discussion/599946/mcjframemaker-is-online-frame-your-renders-as-stills-later-as-slideshows
https://sites.google.com/site/mcasualsdazscripts10/mcjframemaker
mcjSlideshowVideoMaker can use these frames to create slideshows or stills or standard videos from collections of images
in the video you can see I presented 240 images as 30 slides, each slide is shown 6 seconds and there's a cross-fading effect between each slide
By standard videos I mean, say you rendered a 1800 frames animation as image series, then you set mcjSlideshowVideoMaker's
frame rate to 30fps and you got your 60 seconds video plus an audio track (mp3) of your choice.
Video :
Post edited by mCasual on
  • mCasualmCasual Posts: 4,607
    edited November 2022
    Latest Slideshow video produced with mcjSlideshowVideoMaker
    HD 1440P VIDYO ! ===>
    Updated Updated Updated Updated Updated Updated Updated
    The [Run MakeVideo.bat] button didn't work
    ( because I prefer to run the makeSlideshowVideo "manually" so I didn't test it in a long time )
    so it's now fixed just download and unzip the new zip package in your content folder
    read the [ HISTORY ] section to see the date and time of the update
    1080 x 1920 - 1M
     ** Critical Update **  ** Critical Update **  ** Critical Update **
    i fixed an issue with the path to makeSlideshowVideo.bat
    it was getting stuck to the location of the first makeSlideshowVideo.bat path and filename that you created.
    Though doing a factory reset was a workaround. ( if you used this trick, you get 10 points )
    1080 x 607 - 184K
    Nov 22, 2022 Fixed the creation of the batch file for Standard Videos, sorry i waited 3 days to give you this version!
    In the near future mcjVidYoMaker will do what mcjSlideshowVideoMaker and mcjFrameMaker can do and more, like the layout with various cell sizes as shown in this video
    edited December 2022
    mcjFrameMaker and mcjSlideShowVideoMaker News
    this here shows that i found a way to present users of the next version of those scripts (they may be merged into mcjVideoMaker)
    ... with the complete set of possible and sane layouts for a given grid
    in this case a 3x2 grid
    there were 128 combinations of the 7 walls, and only those made sense
    and here's a recent video made with mcjFrameMaker and mcjSlideShowVideoMaker
    and this one which is less scary (for people scared of ghost pics )
    1024 x 341 - 15K
    UPDATE UPDATE UPDATE UPDATE UPDATE
    example:
  • Nice work. Thank you
    Small but important Update
    HISTORY
    364 x 364 - 118K
