Move files on other disc
Hi there,
Is it possible to move files from DAZ to another folder?
I mean i'd like to push all the folder "My DAZ 3D Library" on an other Hard disc...
Thank you for your support.
Hi there,
Yes, as long as you select the new location as a content directory (you need the folder that holds the Runtime and Data folders). Daz Studio and the Content management System don't care where the content directory is as long as they know, and as long as the files are in the correct relative location within it.
If you installed through Install Manager or Daz Central those do track the exact location of the files, if you kep the zip there is an option (after updating the destination path) to reinstall using current directories in Install Maanger (right-click in the Installed tab), otherwise you can batch edit the Manifests folder's .dsx files to have the new path.
