cannot take the glossiness off of g8 with n-g-s-anagenessis-2 applied
VicSVicS Posts: 1,273
i tried every slider in surfaces , glossiness, top coat, glossy layered wieght
this image is with a spot lite, without a spotlite it is a little gloosy in some places but nowhere near as bad
will be good to know how to cut it down for both scenarios
thanks
  • Moved to Techncial Help - please post questions about products here, not in Daz Studio Discussion.
  • VicSVicS Posts: 1,273
    ok
  • @VicS To remove the glossiness, try lowering or turn to 0 (zero) your Dual Lobe Specular Weight, your Lobe Roughness controls, and/or your Base Bump.
    NOTE: If you don't see these controls, set your Base Mixing to PBR Metallicity/Roughness.
    edited December 2022
    thanks Robert , will try later in day, tried it works fine, thanks again
    Post edited by VicS on
