rifle from carnival midway jumps when parented to genesis
VicS
i even expoted as an obj but it still jumps
fit to none doesnt work
Is Parent In Place on?
I'm leaving this one sicne it is perhaps a geenral suage issue, but please don't use the Daz Studio Discussion forum for questions about specific products - those generally should go to Technical Help.
I wanna do this scene right now so was just hoping someone may know the fix to this
tech help if they do respond may not even know this one
im dragging rifle into genesis or to the left hand where it does jump as far away,
dont know what Parent In Place on means
Technical help forum https://www.daz3d.com/forums/categories/technical-help , not support.
Parent In Place is a check box at the bottom of the Change Parent dialogue or, if you are using Drag and Drop in the Scene pane, it's a checkable command in the Scene pane option menu - the lined/hamburger button in the top corner, or rigth-click the tab.
ok thanks !
