Activating a morph on the base figure when fitting clothing
When loading or fitting a clothing item, is there a way to activate or dial in automatically a morph on the figure to which it is fitted?
How do you achieve this?
Wearable preset. Select the figure you're fitting the clothing item to and then save as wearable preset. Under the shaping tab you'll be able to select the morph you want active on the figure.
Ah thank you, i was just reading that in another thread (which unfortunately didnt find before making this thread) https://www.daz3d.com/forums/discussion/131011/applying-custom-figure-morph-when-loading-a-clothing-item
