Sorting of assets in Smart Content broken?
Hello everybody,
when sorting in "Smart Content" by:
- Release Date
- Order Date
the sorting order isn't right. "Install Date" works fine. Is this a problem with my installation or do others experience the same?
This has been true pretty much sisnce the store system update. It didn't take any chnage in DS to trigger so presumably it is a store side issue.
Ok. Thank you.
You can see the info the store is giving if you select an item in Smart Content and look at the Info tab at the bottom.
