Daz 4.21 render coming up bumpy
Probably the wrong category.
But lately when rendering any V6, Lilith, etc. They come up as lizard like scales.
I have tried deleting the cache and appdata temp.
Removing clothes if something was causing it there....no change.
Changing Bump and displacement....no change.
Any ideas?
  • felisfelis Posts: 6,124
    Is it only Lilith that is a problem, i.e. other Genesis 6 are ok?
    And if, maybe try to reinstall Lilith.
    She looks fine for me, using Iray and latest beta.
    1300 x 731 - 927K
  • It is all or most Genesis 6 for some reason. just began occuring.
    Aneta and Carissa don't have the odd texture.
    May have to try reinstalling the figures.
    I had this when I went from being a member using 4.9 at the time and then 4.2 installed itself. I had to do a full reinstall. which I do not want to do.
    Thanks.
    It is a bit strange that it is many but not all Genesis 2 characters.
    Maybe try to look in the log (Help > Troubleshooting > View Log) to see if there comes any warnings up related to textures when loading a character or when rendering.
  • IceCrMnIceCrMn Posts: 2,331
    Looks like there's a texture map being tiled (none of them should be) at the shader level that was used on the most of the skin, except the ears. They look normal from what I can see in the screenshots.
    What shader are you using?
    What render engine are you using?
  • Thanks for the help and ideas.
    Nothing in the log on missing textures.
    Shader is same as default (Hate to say, I don't know how to change it): AoA Sub surface (RSL)
    When I look at tile settings of texture. All are at 1 on any figure.
    The render is: 3Delight (RSL)
    Trying a Nvidia render now (That will take a few hours)
    Plan to reimport content tonight.
