Corrupted Genesis 8 Base Female issue
I KNOW (or deeply suspect) that this is a PEBKAC problem, the result of trying to edit/save several character morphs too fast, so help/tip/pointers are requested.
Somehow, I've managed to corrupt my Genesis 8 Base Female model. I was playing around with several character morphs, and now I have the base character corrupted with the morph. When I call for the Genesis 8 (or 8.1) base models, they come with the morph applied. I can recover the base shape model by then zeroing out the figure (Edit->Figure->Zero-> ), but then, if I load any other G8F character I have, the character is loaded on the corrupted base G8.
I have completely deleted the associated morph files (original character and associated data morph files) from the corresponding DATA and PEOPLE folders.
Using Install Manager, I've removed and reloaded the Genesis 8 Female (and male) starter essentials; cleared the caches (using the F2 preferences dialog.)
In the image, the G8F base model is in blue basic wear. The G8F 'zeroed figure' model is in pink basic wear.
Any suggestions to help recover the G8F base model?
Based on a tip in a Facebook post, I removed all the characters/morphs I was working with at the time and I got my G8F back!
Now, hopefully, as I add them one by one, either it won't happen, or I'll find the offending morph!
Thanks! will keep that for when it happens again!
