Translate and Rotate Tools are far away
Sometimes the Translate and Rotate tools are a good distance away from their character. Is there a way of resetting them so they will be on or near the character?
That usually means that the character has been moved using the hip bone and you now have the figure node selected. Zero the hip translations and use the figure node instead (the hip should be used only for the relatively minor offsets needed to keep the feet on the floor or for relative positioning in a multi-figure pose).
