(SOLVED) Filament (PBR) doesn't work or something
NGHTMRE
Well, I wanted to try the option "Filament (PBR)" in the Viewport and when I select it, the figure that I import into the scene turns all gray. I have seen some videos and I see that this does not happen to others.
What could be the problem?
I attach images of the problem, btw
Thanks for the attention.
EDIT: If anyone is experiencing this same error, try turning the "Hardware Anti-Aliasing" option to "Off". That was the solution for me.
I attached image of the solution, btw.
Post edited by NGHTMRE on
I have no clue. Sorry
Is that on a mac or Windows?
as far as I know Filament isn't working on macs.
https://www.daz3d.com/forums/discussion/449631/filament-does-not-work-on-macos-yet
I don't have a mac so can't be of much help with those.
Thanks for answering. I am using DAZ on Windows.
But I have already fixed it, I just had to disable the "Hardware Anti-Aliasing" option and it works perfectly now.
