Pairing a 2080ti with a 1080ti Pros and Cons
Okay, I know there are way newer cards out there but I'm broke and on a budget. Here are my system specs:
CPU: Ryzen 7 5800x
Memory: DDR4 3200 48GB
GPU: EVGA GeForce GTX 1080TI 11GB
SSD: WD Black SN750 1TB and 2TB
From what I understand, if you have two graphics cards with different VRAM amounts, Iray will default to the one card with the most VRAM if the scene exceeds the amount of available memory on the smallest card. For this reason, I don't want to get a card with less than 11GB of Vram as I'm already having trouble staying within that limitation.
I'm on a tight budget so I'm looking to either a second card like mine or maybe the 2080TI to pair with it. I figured I could really cut down times with a card with ray tracing. Would I see enough of a performance difference in getting a 2080ti instead of another 1080ti to pair with what I have? I can get a 1080ti for $250 vs $350 for the 2080ti.
I recently got a RTX 3060 12GB for $324 from Newegg. Looks like they still have similar pricing.
MSI Ventus GeForce RTX 3060 Video Card RTX 3060 Ventus 2X 12G OC - Newegg.com
MSI Ventus GeForce RTX 3060 Video Card RTX 3060 Ventus 3X 12G OC - Newegg.com
And on an open box even less:
Open Box: GIGABYTE Vision GeForce RTX 3060 Video Card GV-N3060VISION OC-12GD - Newegg.com
And yes, you will notice the difference. I upgraded from a 1080 TI
For Iray the 3060 12GB is about the same speed as the 2080Ti, and has an extra GB of memory.
Awesome, thats good to know. Thanks :).
