Bed sheets in PerspectX The Morgue ???????
https://www.daz3d.com/the-morgue
Clearly, the exploded shot of the props/set show SEVERAL sheets in the shape of a would-be corpse.
I do not see them anywhere in the set. Is it possible, an almost clay render shows stuff that is NOT included.
Say No Way Daz Studio.
  • DaventakiDaventaki Posts: 1,624
    That seems to be the case the sheets are not in the set and not listed in the readme.
    Autopsy and RL Morgue have sheets. And doing some yourself using a plane primitive and dForce would be quite easy.
  • And doing some yourself using a plane primitive and dForce would be quite easy.
    Even easier than all that, is the product coming with all the stuff the technical promo advertises.
    The Sheet in RL Morgue looks fantastic. Thank you- that is a great option. Bookmarked!
    I have no idea what you mean by "Using a plane primitive"....unless you mean to make it a dForce-able object???
    Unfortunately, dForce is out of the question- as Daz Studio version XXXX, the nVidia driver XXXXX and the latest Windows update XXXX are not friends right now.
    I used the sheet from Autopsy (lucky I owned that too) and used the surface opacity and clever camera angles to hide all the figure parts that didn't work.
    I also own the Alien One https://www.daz3d.com/alien-autopsy
    Arhhhh- now that I study that one closer, I should have used that one, That's what I get for not going with The AntFarm in the first place....
  • vagansvagans Posts: 422
    dForce is fixed in the latest drivers.
