Clothing/extracts made in zbrush posing in DAZ?
I know we are able to keep deformations and subD levels between DAZ and Zbrush but is there a way to allow clothing articles made in zbrush, on the DAZ model, to be posed in DAZ on the same model? Character Creator has this feature and daz may verwell have it I'm just doing it wrong, so figured I'd ask.
I'm not sure what you mean, if you are wanting to make clothes for a Genesis figure or other natively rigged figure then use the Transfer Utility - Edit>Figure>Transfer Utility), set the Source to the figure and the target to your mesh from ZBrush, it is better to use the zeroed figure as the object to model around if you can
